How do I take off the Spool housing , to re-feed trimmer line - No Manual misplaced or garbaged. model # 51352 Serial # 270000339
SOURCE: I can't remove the spool to replace the line. How
there is a button on the end of the shaft. it can be tight sometimes so a large pair of channel locks might help. turn the button counter-clockwise, and the pull the spool head off.
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
SOURCE: refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need opposing force.
