Paint on bottom peeling...what to do...is it a danger if left
Yes it is a certain danger, DO NOT USE your microwave until this has been repaired. You should be able to get specialist paint and kit from your local hardware store. Here's a handy kit I found online:
Microwave Oven painted lining repair kit MSC TOUCHUPKIT
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing, which can be messy.
SOURCE: microwave oven
THERE IS SPECIAL MWAVE CAVITY SPRAY .MAKE SURE YOU SANDPAPER IT THEN USE NORMAL PRIMA ALLOW TO DRY USE FINE SANDPAPER JUST TO MAKE SURFACE RIGID THE SPRAY
SOURCE: paint peeling inside microwave
If the unit has been operating properly for some time with no issues, I would say it is fine to continue to use. The issue I would have would be with the possibility with the paint falling into the food.
It would be interesting for you to call the manufacturers' support line and ask why this is happening. Maybe they will offer you a replacement if it was a manufacturing process defect. Mention that the paint may have fallen into the food.
Please let me know if I can be of further assistance to you.
- Jim
SOURCE: paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
SOURCE: the paint is peeling inside the microwave, is this
Yes it is! if this goes unchecked the magnetron will arc where bare metal is exposed and eventually it will short out destroying a very expensive part.
