Generic Taski 8500 600 Bora / Baby Bora Vacuum Cleaner Bags, 10 Pk Logo
Stephen Purcell Posted on Mar 20, 2014
Vacuum won't turn on
When plugged in it won't power on, it has a new bag in and the filter is clean, it just wont get any power
A
Anonymous
Change the switch this is very common the switches go out and that is the only thing wrong with it causing it not to get power
Sharp EC-T4660 vacuum cleaner does not pick up fuzz particles on carpet. New bag, suction hose is clean and open.
A vacuum with weak suction can turn a simple chore into an exhausting workout. Try this quick fix to make sure your vacuum picks up everything in its path. Step 1: Clean the bag or canister and filter. Check to make sure the bag or canister isn't full and that the filter isn't dirty.
I took the filter out of my Windtnnel Pro Pet to clean it (not with water) I put it back in and now the vacuum wont turn on.
I'm going to guess that when you put it back together it didn't quite go back in correctly. There could be a switch that prevents it from turning on if the filter is not installed. Make sure that it is seated correctly. I hope thats all it is.
Dust bag ripped, now wont turn on
dust bag not the problem so take into guarantee vacuum and sewing center and they will clean it out completely and get it fixed and running like new at as little cost as posible
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
1helpful
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 • Vacuums
Riccar 1700 won't power on, outlet is working, no
If this problem happened after you replaced the filters, check that the filters have been installed correctly because some filters have sensor magnets installed on them and unless they are in their correct position, the machine wont power on.
I hope this helps you
MobileJB
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
2answers
Eureka 4331 (Boss Lite) vacuum doesn't pick up dirt anymore
I no more use Eureka 4331 (Boss Lite). But the most common reason for not picking up dirt might be the vacuum bag might be full. Need to be Clean or replace as recommended by the manufacturer or The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner's manual for cleaning instructions. I recommend having Eureka Power Speed for yourself. 7_21_2021_9_09_38_am.jpg
Top Generic Vacuums Experts
john h
Are you a Generic Vacuum Expert? Answer questions, earn points and help others
