I need to reset the default password on the router
SOURCE: Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
SOURCE: username and password
if this is fresh from the box, the factory default will be (username - admin) and the (password - admin). but if this already configured by the user before, all you have to do is restart it so that it will back into factory default.
simply press the "reset button" for 10 sec...
then try to login as a factory default then configure it again
SOURCE: anyone know default password for actiontec gt704wg dsl modem
The default settings are:
Username: admin
Password: password
SOURCE: Asking for password, but never needed one before
If you are referring to the web interface, the default settings are:
Username: admin
Password: password
SOURCE: What's default password and user name for Actiontec GT704WG
Default username is admin.
Default password is password.
I hope this helps!
Testimonial: "Thanks for the right answer!"
