Samsung LA26R71BD 26 in. HD-Ready LCD TV Logo
A
Anonymous Posted on Mar 19, 2014
Auto retune reset
How do I channel auto scan
in most tv'd there is as a channel retune option from pressing the menu button and selecting setup and then selecting retune. In retune menu there would be a manual retune or an auto retune option.
Karen if you provided the Make and model number of your particular television someone o fix ya could find the user manual most likely and give more precise instructions on how to do this.
1helpful
LG set have suddenly lost all BBC channels
you need to do a factory reset.. using 0000 retune so the beeb says
Auto retune window wont go away after retune
Dont stop or quit tryin to fix it and im sure itll fix itself for you
Have lost all my hd tv stations
Hello
Just reset the TV to factory settings and retune it using auto tuning fuction from the Menu option.
To reset it to factory settings, do the following:
Turn on the TV. While holding down "UP arrow" button on the remote control, press the POWER button on the TV. [The TV will turns itself OFF and then back ON again. Release the "Up Arrow button.
This operation will clear all your customized settings including Paremtial Lock settings.
in otherwords, this is the process to unlock the TV if it is locked.
Retune it by autotune fuction. All the lost stations will emerge again.
Ok.
I cant retune my proline tv/dvd combo as there is no retuning option in the limited menu.no option to reset on the controller either so have no signal now since swithover.how can i get it to reset anyone?
Some TVs brands - I believe Proline is one of them - cannot be retuned when you are in Digital mode. If you switch back to analogue mode, then press the menu button, the option to auto-scan should be available. Once you retune, switch back to digital mode.
Try this and post back if you need further assistance.
Please rate this solution if you find it helpful. Thanks.
4helpful
Samsung tv will not retune
HI
1 Turn off the TV so its on standby
2 Then press these keys one after another
Info, Menu, Mute, Power.
When the TV turns back on you are in the Service MENU.
Now press your down arrow key until you get to number 12 on the on screen options,
It’s marked RESET.
Push the arrow key to the right, to RESET your TV.
Next simply follow the instructions on the TV to retune your channels.
OR
Press D.Menu on your remote. Select Channel. Auto Store.
That should do too.
Thanks for contacting fixya.com
6helpful
Unable to retune digital stations on sony KD-28DX50U the auto tune option is not available for digital stations
Open the drop-down panel on the front of the set and push the recessed button using a pen or similar item. The retune screen will ask if you want to rotate the picture, press OK which brings up the retune screen iteself. Press OK for auto retune to start
10helpful
WILL NOT RETUNE CANNOT FIND INSTRUCTION BOOK
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
3helpful
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Resetting a sony television to receive digital programs
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
