Question about Homelite Leaf Vac Attack
Need a user manual for Homelite Vac attack 2
Lost my user manual. I have UT08544 but any user manual for any model Vac Attack would help.
    Problem Solver:
  • 5 Answers
I have a Homelite UT08107
Leaf Vac, I couldn't get it started so I took it completely apart and cleaned it all up and now I can't figure out how to put it back together. I'm looking for a shop or a servive manual
Posted on Sep 04, 2009
    Problem Solver:
    New Friend:
I need instruction manual missing from box
Posted on Nov 10, 2009
6ya staff
SOURCE:
Blower Vac HBL26BVN. The plastic primmer button has split. I cannot get a relacement. Help
Try this link:
http://www.ereplacementparts.com/homelite-ut08544-vac-attack-parts-c-18807_18808_139650.html
Jun 18, 2014 | Homelite Leaf Vac Attack
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Does my vac attack 2 need crank case oil?
It will have a 2 stroke engine, so the oil will be mixed with the petrol, so no you won't need any crank case oil.
Nov 09, 2009 | Homelite Leaf Vac Attack
Does this blower use 2 cycle mix; I have a homelite vac attack II 200mph blower and it is having trouble starting
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Oct 12, 2009 | Homelite Leaf Vac Attack
What is the gas ratio for Homelite Vac Attack II
The mix that I would use is one ounce of two cycle oil per quart or four ounces of two cycle oil per gallon of unleaded gasoline. Hope this helped and best wishes.
Aug 31, 2009 | Homelite Leaf Vac Attack
Need to know the right gas to oil mixture for a Homelite Vac Attack UT08107A
All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils
May 22, 2009 | Homelite Leaf Vac Attack
Can't figure out type of carburetor on my leaf blower.
I have seen 2 different carburetors used on this unit. A Walbro and a Zama. You will need to get the information off the carb. (Walbro WYC-10 or Zama K39A) are the two I have seen, but you need to be sure what yours is. Then purchase the correct O/H kit and rebuild it.
Apr 10, 2009 | Garden
Homelite Leaf Vac Attack Logo
3,194 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Joseph Mueller
Joseph Mueller
Are you a Homelite Garden Expert? Answer questions, earn points and help others
