Mitsubishi ws55613 - I lose the picture from my Direct TV source every 30 seconds, then the picture returns but goes out again and again. Recently had the blinking light problem fixed by TV repairman making changes to DM Board. Also remote on/off switch won't work but Power button on TV works - remote works after TV is turned on for using other functions. Thank you in advance for your response.
SOURCE: Where is the Dm board? Does anyone have a picture for this model
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
SOURCE: TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
SOURCE: constant green blinking light Mitsubishi tv WS-65513
A quick fix for this is to use a hair dryer to heat up the capacitors and then plug the tv back in. It should only take about 90-120 seconds to heat them up depending on how hot the dryer is. The cap's are located on the right side. Take the front cover off the TV, and heat up the box that is about the size of a small cable box on the right side. Once the cap's are warm, they will stay warm as long as the TV stays plugged in.
Scott out
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
