Insert dvd or cd and the machine tries to read but then comes up with message no play then DVD HO2. Have switched off and reconnected but same error appears.
SOURCE: dvd wont play ...each time you insert a DVD it shows DVD HO2...
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Thank you Stuart for the pencil idea it solved the problem my dvd is working again.
