Press program
then 0
(this will then display current date and time - overtype as follows)
eg. for Friday 2nd November 2007 8:58 am you type the following
071102 (date backwards) [space] 5 (Friday is 5th day of week) [space] 0858 (time) [space] 0 (0 is am, 1 is pm)
Press the store button and then program button to exit the programming.
You need to have the main phone,
1. Press the programme button
2. then *#1234
3. 000
4. SP-PHONE
then CONF (L) and/or FWD/DND (R)
finally press STORE/AUTO DIAL to finish
Why they don't put this in the user manual I have no idea but it would make life so much easier for everyone.
NB to find out which is the main phone, if you try these steps on any other phone it will beep 3 times by the time you get halfway through step 2.
Good luck everyone.
You need to make sure you are doing it on the main extension - usually 101. On other extensions it won't work and you will get the 3 beeps.
I need to figure out how to change the time and date on this phone, please. Also...If I have messages on the phone, how can I check that as well.
Thank you
Chrissy L
If this telephone is connected to a electronic modular switching system, please refer to the user manual of the system and just follow the simple steps and presto.. tnx
SOURCE: Change the time and date on Panasonic KX-T7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
SOURCE: Is there a Panasonic cordless kx-t7730
The chances are, if you have CID you don't have to worry....the first call after 3am will fix it. If not, programming from extension 101 and 000 will fix it.
Any industry standard cordless phone will work on a Panasonic system...are you plugging it into a system phone port with the sytem phone? If you are trying to make both work on the same port, you have to tell the system that. Program option 610 in a TA series or 600 in a TDA series will set a Paralleled phone so both can work.
If you don't know how to get into System programming, your installer or dealer should.
Carl
Followed all instructions, time was correct when typed in but it did not change the time after pressing store and program on the system
I press Program then "0", and I get three beeps. It seems that I am getting an error of some type. Is there a solution for this?
3 beeps after I enter program and press 0. Can't change the time. HELP
how to change date & time for kxt 7731
I have the same problem as the user dated the 06/11/07. I follow the instruction and when I press store / program I get three bleeps and the date and time dont change. Can you help?
The time did not switch from daylight saving time. When I press program and 0 as suggested nothing happens. HELP
cant set time, help!!!!!!!!!!
I cannot figure out how to change the date and time.
Can someone advise how to change the time on the Panasonic KX-T7730
