Samsung SyncMaster 740N 17" LCD Monitor Logo
n
norsu Posted on Mar 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When bios on monitor will display few secons then it will no longer display
I need to fix it help me
Mike M
Level 3:
  • Samsung Master 3,349 Answers
  • Posted on Apr 06, 2014
 Mike M
Samsung Master
Level 3:
Answers
3349
Questions
0
Helped
686674
Points
16707
Cables, video card, resoltion. Update BIOS
Toshiba satellite c675 monitor light up but not displaying anything
Hook up an external monitor to determine if you have a logic board or LCD problem If the external monitor works the trouble is with the display or its cables. You should also double check that your memory is properly installed and you may want to replace your bios battery. you will need to aquire a toshiba manual for your laptop to help you fix these issues. here is the link for finding your manual Search
My dell monitor wont display my pc image
Make sure you use the correct selection for your input (the leftmost silver button) to cycle through DVI-D, D-Sub, S-Video, and composite.If you are using this as a second monitor from your laptop, you have to activate the secon dmonitor using your keyboard or the operating system.
3helpful
The display turn off after few minutes (blank screen, no message). When it does that, the power led stay green. When I turn it off and on, the display work again for a few minutes and the same problem...
jackperson, Might be internal problem with the units power supply (ac line in to DC conversion) having shutdown issues. You will need to do some reading in my fixya profile for a while and then you will know what to look for inside unit. If not into electronic repair stuff, skip the reading and trade-in unit for new, if current unit is 4, 5, 6 years old. 12fixlouie
My dell (monitor) it turns on few secons but the image goes off,
First you'll have to power off the system.
Please power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
The computer will go to the system setup. Check if the screen goes blank here.
If the screen stays on then try this.
1. Please power off the system.
2. Please power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll reach the Windows Advanced Boot Options Menu on the screen.
3.Select Safe mode with Networking.
4. Select Administrator at the log in screen.
5. Warning dialog box with the message Windows is running in safe mode. appears. Click the Yes button.
6. The desktop appears with the words Safe Mode appearing in all four corners.
7. Uninstall the video drivers and restart the computer.
8. Resintall the video drivers.
Rate if useful.
Can not get card to display on the monitor
Have you set your system to use a second monitor? Right click the desktop and choose Properties. In the Settings tab, click the 2nd monitor and check the box that says Extend my windows desktop onto this monitor. If that fixes it, please rate me accordingly. If not, let me know and we'll try something else.
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
2answers
Flickering display
if it happens with external monitor then it's probably video card.
most likely a cold solder joint on the board. OR if it's a plug in type board it might just need to be re-seated.
Samtron monitor color display 56V
there are 15 Pins in Monitor cable which is connected to VGA port on the rear side of the Tower. First, we need to reset BIOS settings, and then try again - onboard video card only. for Add-on Video card try reseating video card in diff. slot if possible / reseat video card and try again. if it does not fix it, it could be the problem with Monitor RGB Connection - near the electron gun in the monitor CRT tube. resolder RGB , it will fix it.
by
Kasi M
Monitor no Desplay
reset the bios jumper settings,jumper it to 2 and 3 terminal, or do the erasing of memory card.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
