Bad DVD player ( Karaoke )
My unit has on the left side, a cassette player, on the right aDVD player,the cassette still works fine,the DVD tray I pushed it in and started going in and out non stop one Day, I pushed it in never open again, but Prior to getting stuck never played .needs Some one with electronic skills, I tried almost Everything.
    Habit-Forming:
    New Friend:
  • 73 Answers
Th fault is on your disk tray mostly. Just try to switch off your player once and then restart it again. If that doesn't work then try to open the screws in the DVD player only the disc portion and try to check whether there is a damage on the disk tray.
Posted on Nov 23, 2017
6ya staff
SOURCE:
Anonymous
  • 196 Answers
SOURCE: jammed sony dvd
Unplug the power cord for at least 30 seconds, then try again.
Posted on Jun 10, 2007
sandrew
andrew pester
  • 2961 Answers
SOURCE: Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Posted on Sep 06, 2007
Anonymous
  • 61 Answers
SOURCE: Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Posted on Jan 27, 2008
Anonymous
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Posted on Jun 01, 2008
I need a operator manual for a lonestar sk-104 karaoke manchine
I have the same one. and I have had another model also.they are almost the same.If I am correct it is a cassette karaoke player.They take a special cassette that says lonestar super K.these players and tapes were from the 1992-1994.when you hook to the tv, the tv needs to be on channel 3 or 4.the back of the machine should have a switch with 3 &4.make sure both are on the same.on newer tv you may have to figure out the input & output.some say video some say line 1 line 2 etc.my machine uses a cable cord from tv to machine.any tape will play in them ,but only the special ones will put words on the tv. if you use the special tape when you put it in the machine only one side plays.it tells you on the tape.also only one side of the duel cassette compartment will put words on screen.my sk104 is side B.Hope this helps.if you still cant get on screen words,it could be that part of the machine just doesn't work anymore.that is what happened to my other one.
Dec 15, 2012 | Music
Magnavox vhs and dvd player vhs insertion issues
Someone is going to have to take the unit apart---mechanism issue with the tray or the gears that lower it etc---not too many shops left that work on VHS decks anymore so call around first.
Dec 03, 2012 | Televison & Video
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Dec 31, 2009 | Philips Televison & Video
Dvd will not eject from jvc hr xvc27u dvd player all it will do is display the word read on the screen
elsombro is right. There is a little whitish plastic square on the right side of the player, part of the DVD assembly (after you take off the cover). It's about 1/4 inch square. With the unit turned on, push that square with a pen about 3/4 of an inch in or as far as it will go. There will be a clunking sound but that is the sound of the DVD being released back onto the tray. Now gently push the back of the tray forward, ejecting the disk manually. Take the disk out and then press the close button. If the door doesn't close, it's out too far so manually push it in about an inch or so and then press the close button again. Should be fine after that. I think my problem was a DVD I recorded on my computer and it has the wrong format or something. After I got it out I put a regular DVD back in and everything was fine.
Dec 30, 2009 | JVC HR-XVC27U DVD Player/VCR
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
Cd & g drive quite working
I had the same problem. The fix is a bit unorthadox. I removed the 4 screws holding the circuit board that is mounted directly under the CD player. Now with the board hanging free the unit works fine.
Good luck.
May 19, 2009 | The Singing Machine DVD/CDG Karaoke System...
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
1995 Saab 900S Left speaker doesn't work when using tape player
sounds like the cassette adapter has a bad channel, or didn't fully seat into place. Try removing and re inserting, to play the other side of the adapter if the wires will allow it. Then auto reverse the cassette deck to allow a different portion of the cassette head to be used for the signal. Those cassette adapters are poor quality, and put alot of time on the mech.
Jul 12, 2008 | 1996 Saab 900
CAVS DVD 105G having trouble reading super CD-G disc
just got the CAVS 105G and the tray will not open.  Could there be a shipping brace that needs to be unfastened in order to open the tray?
Jul 09, 2008 | Cavs DVD-105G
47 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
