WD 73733 tv; replaced bulb 1 month ago, tv runs for 4-5 hrs then black screen w sound & red lamp indicator. Power down for several minutes, tv resets and powers on. What's broken?
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
I would venture to guess the bulb figment is your issue and the electrical sound is most likely arching (very bad). The cheap replacements won't last. I bought a sylvania build and matched the model number with the one from inside the old bulb housing. Changing out the bulb from the casing is really easy so just return the one you bought and buy the corresponding bul without the case.
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
Yes the Lamp can fail within that time frame. Much of it depends on how many hours the set is running. Most Lamps have a 3000 to 5000 hrs of life. But with any Halogen style Lamp, this is not written in stone.
Hope this helps,
Skyassoc
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link. http://servicemanuals.vstore.ca/
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
