I havent used it in a while but just tried to turn it on and it keeps saying safe out. How do I get it back to normal mode?
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
There is a safety mechanism on the bottom of the computer. It is a magnet, with a string attached, and a clip at the other end. You're supposed to clip it to your clothing so if you fall off, it pulls the magnet out and stops the treadmill. But to get it to start again, you have to put it back in that round hole on the bottom.
Hi I've got a treadmill Brand name Digital Treadmill. When you turn it on "error 7" comes up all the time. There is nothing I can do to romeve it. Nothing works. Please help.
Tui
bowflex series 7 treadmill stuck on incline mode
