Put quad into reverse and quad continues to go forward not backwards what would cause this to happen
For some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
