The door keeps opening during the wash in all washes except the eco wash
SOURCE: tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
SOURCE: Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
SOURCE: Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new. That was quite an axccomplishment since the machine is 15 years old.
SOURCE: Dishwasher Detergent Dispenser not opening
An automatic dishwasher
detergent dispenser door can become stuck for a few different reasons.
Some problems are easy to fix, while some require more work. Repairs
are basically the same no matter what brand of automatic dishwasher you
have, although specific parts might be required. Fortunately, even if
the detergent dispenser needs to be replaced, the problem is not an
emergency. The dishwasher will clean dishes fine even with a stuck
detergent dispenser.
Fixing a Stuck Automatic Dishwasher Detergent Dispenser
