Model GBD307PRB01 Control Panel works and oven looks like it is preheating but no heat. Flipped Breakers (40 amp should it be 50 amp?) Had electrician in for finishing basement, added Sub-Panel, oven stopped working that night - coincidence?
SOURCE: Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto
this data sheet might help
For all Free appliance repair videos visit our VIDEO
TUTORIALS
1, If the fan motor in the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter.
To gain access to the element you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the element you will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the element
is open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to
cook or is burning the food more on one side than the other, then you need to
check if your oven fan motor
is working you will
see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then
you need To replace the oven fan motor
is a little more
expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat
and no fan then the chances are that someone has put the oven timer
into AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
SOURCE: Whirlpool Gold model #GS395LEG oven control panel
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: The elments in my oven will not heat up after I
The model number that was posted will not come up in our database. Please read the process below to obtain this information, I did come up with a RBS307PVQ00. Or scroll down to the procedure on how to check your oven.If you would like I can post a "how to use a volt meter " video that shows you how to check power and continuity. Please let me know how you make out. If you have any other questions or concerns please post them. Link for all appliance model numbers. Please post your entire model number. After you have clicked on the link below.... Just to the right of the "search" tab click on "help me find my model number" Just click on the model of your choice In either video or image presentation Then please re post the information. Click on the link http://www.repairclinic.com/Appliance-Parts Thanks.... Keith Heating Element
This is usually the problem. To Check this first turn oven on to a bake setting,say @350, check to see if element glows, if not shut oven off. If it is warm but does not glow it is getting power and the element needs to be replaced. If it does not get warm remove the element and check to see if it is getting power if it does get power replace the element. No power it is the main control that has failed. Check element for continuity, if none replace.
Temperature Sensor
This is a long thin tube like part located usually in the top rear of the oven. It is held in by 2 screws. This can easily be removed by removing the 2 screws and carefully pulling it out. Usually there will be wires connected and insulation so you will need to work it out. Then unplug the connector and check with an ohmeter. It Should have around 1000-1100 ohms if not replace the sensor. Some will have a thin capillary tube attached in this case the problem will be in the control attached to this tube.
Main Control
This can cause your oven not to heat. Sometimes the oven relay gets burned out, when this happens the control is unable to send power to the bake element. There will usually be separate relays for bake and broil if you have 2 different elements. If your heating element gets no power replace the control. If your control does not respond at all check to if you have power entering the control. If you do and it does not respond replace the control. No power to the control Check or replace the power cord.
Problem fixed! Apparently oven was only receiving half power because when contract electrician moved wires in fuse box he accidentally broke off one of the connectors to oven! Service man at appliance repair suggested this was the case - saved me a service call! Thanks!
