LG Microwave / Convection oven. Unit is completely dead. No lights at all. Fuse is OK. Power getting to the printed circuit board. Power outlet (240 volt) is good. Any suggestions? Unit is just out of warranty, and now discontinued. Thank you.
SOURCE: Sharp R1420B Totally dead. Power to unit is ok.
Most of these have internal line fuses inside of the casing. Once you remove the housing that covers the top and sides, follow the wires from the cord and they should lead you to the fuse. They are usually on the front rh side looking at it from the front. Be careful, even though unplugged, this unit still stores alot of electriacal energy in the capacitor.
SOURCE: sharp R-4A56 microwave oven dead
Did you check your circuit breaker to be sure that it wasn't tripped?
SOURCE: dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
SOURCE: Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
SOURCE: My Kenmore microwave model 401.80083700
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
