Wont turn on . if you do lamp heating light continues to flash after the tv shuts oof
SOURCE: JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
SOURCE: JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
If the Fan is clogged up with dirt set will not run fan must be working.
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
SOURCE: JVC HD-61Z786 Projection TV:
There is either dust on the lens or there is a problem deep within the light engine. This is a some-what common problem with these sets. The light engine is very expensive; not economical to repair.
