https://www.timex.ca > Replacement-20mm-Resin-Stra...
Replacement 12mm Resin Strap for Ironman Essential 10 Mid-Size. C$15.99 ... I had to have a jeweler mill down some of the plastic so the band would fit.
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 42px;"> Rating: 3.1 · ‎8 reviews
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Low battery can cause this type of fault! Make sure after changing the battery to do the all reset inside of the watch. If this does not work get in contact with Timex for how to have their watch sent for service.
Hello i Managed to find a PDF Manual for your Timex T3B881. To view you must have Adobe reader installed this can be downloaded from here. The Manual can be downloaded from here.
compass calibration starts on page 8 and compass operation starts on page 12
Setting and Calibrating Your Altitude 1. Press MODE until CAL is shown. 2. Hold SET to begin the calibration. 3. Press START/SPLIT (+) until HOME ALTI is displayed (or choose WEATHER when calibrating weather). 4. Press MODE (NEXT) to begin the setting process. 5. Press START/SPLIT (+) or STOP/RESET (-) to increase or decrease setting values. 6. Set the value to your current elevation. 7. Press MODE (NEXT) to advance to the next setting option. 8. Press SET (DONE) to finish. 9. To complete calibration for the REFRENCE HOME altitude (or WEATHER setting), press and hold STOP/RESET until watch beeps.
Repeat this procedure for WEATHER, making sure to choose the proper weather condition on the WS4 that matches your current weather.
Once these two variables are calibrated, your WS4 will be ready to go, providing you with accurate altitude, pressure, and weather forecast information at your fingertips. Enjoy.
For Temperature calibration: 1. Pull the crown to most extended position (2 notches) 2. Temp hand moves to a default position 3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button) 4. When done, push crown to 0 position (I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration: 1. Pull crown to middle position (1 notch) 2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button) 3. When done, push crown to 0 position
