I bought a ds off of a friend,and the top screen didnt work.
bought a new screen,installed it...
i reassembled the ds and now it wont turn on, i push the power button forward,the green light goes on, and the bottom screen flashes for a split second then it turns off.
symptom: the ds lite powers up for a brief instant, but then shuts off potential solution: disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
Go to the retailer you bought it from and if you bought it less than two years ago you can get a new one free with the exchange of the old one only if you have the warranty
there are 2 fuses you obviously didnt insulate the bottom screen so it doesnt short out on the circuit board look at the one you took out and look at the one you put in difference is one has a backing insulation
did you blob them with solder (definatly not a good thing to do) if you did everything correctly and im wrong try this
the second thing is which every one does they never push the ribbon cable fully home (top and bottom screen) needs to seat all the way in really all the way if this helps give us a tick so to help others good luck
It wont be your DS causing the problem its the cartridge, ive got an Action Replay and it works like a charm, your best taking it back where you bought it from and get a replacement
