Tools & Hardware - Others Logo
A
Anonymous Posted on Mar 16, 2014
Drying out wet drywall - Tools & Hardware - Others
Lewis Richards
Level 1:
  • Contributor 4 Answers
  • Posted on Apr 30, 2014
 Lewis Richards
Contributor
Level 1:
Answers
Questions
0
Helped
1131
Points
I'm assuming your talking about drywall that was wet during a flood of some type? Recommend you remove all damaged drywall and using a straight edge and a utility knife this can be easily accomplished. After you cut and remove the damage, remove all screws or nails from the studs giving a good surface for the new drywall that your going to replace the damaged stuff with. Get that done and we can move onto taping and drywall compound repairs. Hope this helps.
  • Brad Wang Dec 06, 2019
    You'll probably want professional help with this for the best results.
    Mt Rose Drywall Repair Reno
    620 Gordon Ave, Reno, NV 89509
    775-431-2330
    www.renodrywallrepair.com
Paint bubbles on drywall
It's been almost 10 months since the question was posted so how does it look? Most bubbles appear under the drywall tape or could be from primer / paint being rolled over drywall dust. Tape bubbles don't go away. These need repaired by cutting out the bubbled tape and filling in with compound. Tape bubbles can be avoided by using a TapeBuddy taping tool. This tool applies compound directly to the tape so there are no dry spots under the tape. Hope this helps.
May 05, 2014 • Drywall
tip
Fixing textured (not popcorn) drywall ceiling
If you've got a house built in the 90's, you may well have a textured drywall ceiling with a pattern on it. The most common pattern is a blossom texture with patterns of repeating ridges form circles.
The problem comes when you have to repair this ceiling. Knowing how to duplicate the texture is the problem.
Here are the steps to do this:
Replace/repair drywall ceiling until the surface is paint ready, but do not paint. Sand texture off of some of the adjoining ceiling to avoid a visible border.
Make sure you have a drop cloth down!!! This might drip.
Mix drywall mud down to the consistence of pancake batter. You want it stiff enough not to drip, but pliable enough to texture. The mixture should just barely be pourable.
Pour into a paint roller pan, and using a long nap roller with the lint removed (use masking tape) roll the joint compound onto the repaired area.
Allow to set for a few moments to make sure it won't drip Now get out your stomping (yeah, that's what they call it) tool, and texture the ceiling.
You can buy brushes to "stomp" your ceiling at many paint stores, but they aren't cheap. Instead, you can do what most drywall guys do, and make your own. Go to the store and get an old fashioned string mop. When selecting the mop, look at the head. Some have a rectangular bar holding the strings in place, and some have a round tab, about the size of a quarter. You want the one with the round tab, and get one with strings, not cloth strips.
When you get it home, hold the mop up to the ceiling, and note how long the strings need to be to create the same size pattern. Cut your strings about two inches longer, since the whole string does not hit the ceiling.
Trim the strings to the correct length, then soak the mop for 24 hours to limber them up.
Now back to the stomping. Once you have your drywall mud applied, all you have to do is hold the mop over your head, upside down, straight up, with the strings hanging uniformly around the sides. The mop should be damp, but not wet. You can add a bit of drywall mud to it first if you wish, I do not.
Hold the mop about eight inches below your drywall, and starting at an edge where you can judge where to match the old pattern, "stomp" the mop into the wet mud, just like you were stomping your foot. Immediately pull the mop back, and you should have the same pattern as your ceiling.
Continue stomping until you've covered the ceiling. Afterward, you can wash the mop, and keep it for later if you think you will need it.
Tips:
After stomping, let it dry for at least two days before painting.
When you buy your drywall joint compound, look at the prices. You can often get a five gallon bucked for only a couple of dollars more than a gallon. (I always buy pre-mixed, it works great). To preserve the mud you didn't use, after you're done with it, mix a teaspoon of bleach into a cup of water. Level the surface of the mud in the bucket, then pour a layer of the bleach/water mix on top. This will keep the mud from drying or molding.
on Dec 30, 2009 • Hand Tools
Drywall screws show
Use setting type compound for filling over screws. This compound doesn't shrink and does a better job of covering them up. Light weight compound is fine but is soft. It does shrink as it dries so you'll need maybe 3 or 4 coats to get the dimple area covered. I use setting compounds on all my second coats for this reason. This applies to tapered seams, end or surface joints and corners. You want to tape the drywall with all purpose compound that does shrink so it pulls the tape tight when dry. I use the TapeBuddy taping tools for a tight, no blister seam. Let this dry and second coat with the setting type compound and your finishing project will go much faster.
Is klean strip adhesive remover okay to put on dry wall?
Yes-just let dry after-then on prep of wall after you may have to skim wall with a thin coat of drywall compound and sand smooth
2answers
Drywall needs to be painted
scrape a sample of the brown that you want to match, go to home depot and give them the color and they will make you a can that matches. then paint the drywall... i think that is what you were asking???
Mar 10, 2013 • Drywall
Rainbow e series shooting out dust
Did you place water in the water pan? Are you picking up drywall dust, baby powder, wood ash, etc.? This type of material is difficult to be trapped by water.
RainVac
www.rainvac.com
800-523-0510
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 • Vacuums
Troubleshooting
Plug the hose into the other side of the unit. One end pushes air and the other side draws in the air. Now drywall dust will clog your filter quickly. Clean the filter often. Do not clean dust without the filter. It will get all over everything!
1helpful
2answers
Wet dry vac suction not woking
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Dec 17, 2007 • Vacuums
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
