Denon AVR-2802 Logo
A
Anonymous Posted on Mar 15, 2014
Radio tuning without remote - Denon AVR-2802
Acoustic Solutions CMC12CD need to know how to switch from FM to DAB maybe a user manual link as well
Use the rotary Tune/Select control on the HiFi itslef, or the two triangle buttons on the remote control to highlight each mode option until it goes to DAB Radio or FM Radio.
Short press the Tune/Select control on the HiFi or the Select button on the remote control to select the option.
If that works, the manual at the link below is compatible with your equipment.
http://documents.4rgos.it/v1/static/7347948_R_D001
1helpful
How to tune in radio stations on a mini system without the remote
Hi, with just the controls on the unit itself you cannot set the radio station presets. They are set by holding down one of the numbered keys on the remote while in radio mode. The letter P with a flashing number will show up on the display to indicate you are setting that preset, radio will stop flashing and station will be locked into memory.
How do i tune the radio?
Model? brand?
In general, if yours originally had the channel selector and volume control as part of the microphone, the short answer is you don't.
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Tune T.V. without remote
any luck mate? i'm having the same problem. just bout a universal remote to find i still can't get to any menu!
Radio without remote
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
1helpful
2answers
Tuning radio without remote.plese help....
You need to have remote control to perform tuning for radio because unit has no control buttons to do so.
You can get remote from Sony Accessories. Please write model number DAV-S300 in search box to get result.
Remote details are as under...
141883811 RM-SS300 REMOTE CONTROL Approx $70
Remote
Tune the radio to the station you want using the up and down tuning indicators then select a button on the remote for that station and mash it for several seconds and that button should be set for that frequency.  You might have to do the selection on the radio itself instead of just using the remote but once the buttons are assigned they will work with the remote.
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
