Where are the clips located in a 2001 astro rear axle?
You mean the clips that holds the axle shafts in the axle housing? You need to take the cover off the rear axle, now theres a small bolt in the carrier housing that holds the large pin in, remove the small bolt and push the pin out, then push the axle shaft inwards and the clip ( it really looks like a small horseshoe) will fall out, if it doesnt fall out, you will need to remove it, then the axle shaft will pull out. To install its the same way, put the shaft all the way in, install the clip, and pull out to seat it. then install the large pin, but make sure you line up the hole for the bolt.
