Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
will advance one hour.
Or you can ge tthe manual on the link below.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
Solved. Blue wire (remote antenna) was connected to blue wire on vehicle harness. This was switching the factory amp (which I didn't know I had) on in TUNER mode, but off in all others. Switching the blue wire to the blue wire with white stripe solved the problem. Thanks Alpine technical service dept!
