GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it safe to use copper clad pots and cookware on a smoothtop range?
Anonymous
Level 2:
  • Expert 105 Answers
  • Posted on Jun 13, 2009
Anonymous
Expert
Level 2:
Answers
105
Questions
0
Helped
52898
Points
357
No problem at all copper spreads heat better
I have an All-Clad odel 99005 slow cooker and it does not heat. Could it be the heating element and where can I find one?
All-Clad Cookware Limited Lifetime Warranty
From the date of purchase in the US or Canada, All-Clad guarantees to repair or replace any item found defective in material, construction or workmanship under normal use, and following care instructions. This excludes: Damage, including, but not limited to, warping, overheating, pitting, or non-stick deterioration that occurs from misuse or abuse. Damage caused by use of the item in a commercial kitchen. Damage caused by failure to follow use and care instructions. Minor imperfections and slight color variations, which are normal. Damage or defect to plastic components
All-Clad will not be responsible for any indirect, incidental, special, punitive, or consequential damages related to the All-Clad products. Some states do not allow the exclusion or limitation of incidental or consequential damages, so the above limitation or exclusion may not apply to you. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
Should your All-Clad cookware require warranty service, please contact our Consumer Service Department by phone or website per below for a warranty evaluation and return authorization number. Upon approval of your claim, All-Clad will repair or replace the item without charge. If the replacement product is no longer in production, one of equal or greater retail value will be given.
All-Clad Electrics Limited Warranty
This electrical product is guaranteed by All-Clad for a period of 2 years against any manufacturing defect in materials or workmanship, starting from the initial date of purchase.
U.S.A.
GROUPE SEB USA
2121 Eden Road
Millville, NJ 08332 800-255-2523
CANADA
GROUPE SEB CANADA
345 Passmore Avenue
Toronto, ON M1V 3N8
1-800-418-3325
1helpful
2answers
No matter what pot we use, it wont work
Most cookware found found in home today is aluminum or cast aluminum. These do not work on induction cook tops. Even older stainless steel Farberware doesn't work because it is not magnetic. Look for an induction compatible label or stamp on the cookware to be sure.
Induction cookware must be made of a magnetic-based material, such as cast iron or magnetic stainless steel. Fully clad cookware brands, such as All-Clad Stainless, Le Creuset Stainless Steel and Mauviel M'cooks stainless work on induction cooktops because they're magnetic.
2helpful
2answers
What kind of cookware is recommended for glass top stoves
Glass ones work best, but any heavy metal will also work. Heavy gauge not heavy weight. The lighter metal tends to bend and warp after a lot of use. If the bottom of the pans are not absolutely flat, these stoves will not heat the pan very well, which is why the glass cookware is the best to use, since it will not warp.
2answers
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Aircore Cookware instruction
My husband dropped my medium size air core pot today and there s some dents at the bottom, is it not safe to use again?
Can I use an all aluminum cookware pot to cook pork in the oven?
Yes you can. The correlation between aluminum cookware and alzheimer's disease has not been specifically defined and the oven is not too hot for the aluminum pan on anything under 400.
Never the less, you might consider phasing out your aluminum cookware as there are plenty of other types that are less worrysome.
Bon apetit!
Farmerbear
1helpful
Glass cooktop scratched
Unfortunately, these style cooktops are VERY fragile to scratching and cracking. The wrong kind of cookware can also mark them. Copper or aluminum pots and pans can discolor them. Do not use pyrex (glass) cookware on them either. Stainless is the best. NO CAST IRON either. Anyways, there's not much can be done without replacing the top itself.
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
