Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed ·Check empty or damaged ink cartridge ·Clean the dirty print head or replace missing or failed print head
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Electro help . Check the site in 'Mosaic' view. It will make search easy.
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
These blinks (flashes) are fault indication.By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV.Count the blinks occur at one time switch ON, carefully.Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected.If you wish to get more details, check the site linked here.It has blinking codes detail to many brand TVs.Pull up older posts.http://electronicshelponline.blogspot.com/
If the blinking is continious, the fault should be at its main digital board, as these blinks indicates a SDA - SCL probelm, says technically as IIC problem.
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
I had this problem. The cancel button was stucked. Open the toner tray
and slighly push the button side top-cover up. It released the cancel
button for me (actually I was trying to open the top, but it worked).
The cancel button was released and the blinking red-green stopped.
Printer now working.
