The broil pan is used to broil meats such as steak or chops. the top part has slots that allow the grease to run into the lower part. they are usually under the burner in the lower door. but some ovens have the broil element in the oven proper. then the pan should be placed within a few inches of the broil element. You should monitor the cooking process because the broiler heats the food very quickly and could burn very fast.
It is easy to replace. Turn power off to the oven. Remove the screws holding the element to the inside of the oven, Carefully pull the element out of the oven liner until you can unplug the wires from the element. Hook up your new element and ease it into place and re-install screws.
You can get the part from any whirpool servicer or you can order it from Sears.
