American Standard Evolution 2425V-LHO.020 White 5 Feet x Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I would like to know do you have to use Mortar as a bedding material for the model 2425L whirlpool?
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Jun 15, 2009
Anonymous
Expert
Level 2:
Answers
62
Questions
0
Helped
61811
Points
140
No. but it will be noisier when running
I am replacing one 12" floor tile. How much premium two part mortar and part A polymer should I use and how do I mix it
You can buy the polymer mortified tile mortar, not sure if you can get in small bags. As for the grout that the other person answered I have not come across any good premixed grout that are user friendly and the stuff in tubes is not grout but colour matched caulk. Read the labels carefully.
tip
How to Install a Bathtub
Anyone can install a water bathtub, but to do it right so that it will last a lifetime takes some time to make sure that it is installed properly. If installed correctly the bathtub you install will be well supported and will not experience the stress that ones that are not installed properly will experience.
The first part is to make sure that the space is exactly the same size as the tub or tub/shower unit. Leave the end wall out till the unit is in place and then fasten it in place.
If you take the time to notch out for the lip on the tub or the tub/shower unit, your dry wall will not have to bow out over it. Place the unit in place and mark the studs, then chisel out ¼” deep so that the tub sits back and the lip is flush with the face of the studs.
Once you have the unit “fitted” exactly to the space, you are then ready to install the bathtub or tub/shower unit. By this I mean that I “set” the unit in a bed of mortar to make sure that the bottom of the unit and the unit it’s self cannot possible move or flex when weight is in it. To do this you need to make a bed to set the tub into.
Depending on the size of the unit, usually one bag of mortar mix will be sufficient for one fixture. Mix the water with the mix right before you are ready to set the unit. Make sure that the mix is stiff enough so that when you place it on a pile it will stay and not run. Now place the mortar in the center under where the unit will set. Place a sufficient amount so that you will have to press down on the unit to “set” it into the mortar.
Carefully place the unit in place and gently press it into the mortar until it is sitting level. You can now place a couple of screws into the lip to hold it in place until the mortar gets hard. After a few hours the mortar will be hard and will fully support your unit. The bottom of the unit will not be able to flex at all and your unit will be on the road to outlasting you!
You can now finish the remaining wall, then trim the unit and finish the walls. Plumbing can now be installed. Remember to provide access to the plumbing just in case of future problems.
on Feb 27, 2010 • Plumbing
2answers
Help me choose a bed for a child?
Best Toddler Beds
Moms and dads! Are you looking for the best bed for your toddler? Do you want him or her to feel comfortable and sleep well? We bet you do! So, look through our review and choose the best model for rest and entertainment.
Apr 04, 2017 • Baby Gear
Which is the best material for a mortar and pestle?
Mortar and pestle must be made of a hard enough material so that seeds and plants can be crushed without wearing away the tool, and so that the pounding and grinding won't break it.
The material should also be smooth and non-porous so that it won't absorb or trap the substances that are being ground.
There are a few materials that all more or less fit these requirements: ceramic, porcelain, glass, marble, stone, wood, bamboo, iron, steel, brass and basalt.
The choice among these is based on what use you need the mortar and pestle for.
For example rough ceramic is more fragile than stone but makes a finer powder. While glass, also fragile, is stain-resistant. Wood absorbs more easily but is very good for the grinding of salt and pepper at the dinner table. While metal mortars need to be kept lightly oiled.
I personally would suggest a heavy, thick, smooth marble mortar and pestle, as it is both very resistant to pounding, and grinds pretty finely. Marble is good with both liquids and dry seeds and plants, and it doesn't absorb odors and tastes as much as other materials, even tho it does get a bit stained and sometimes previous substances can still be smelled on it for a while.
Sep 12, 2013 • Home
Tuckpointing brick, mortar won't stay in. have a beveled 2 ended tool from lowes does not work
is the recess deep enough on the bed and perp joints if so is the mortar the right consistency.
a little tip is to wet the joints with water before jointing. it stop the mortar drying out to quick
3answers
What kind of materials are cat beds made from?
There are cat beds made from plastic, fabric, wicker, and soft materials. I personally avoid wicker baskets because they tend to get destroyed pretty quickly and can be a pain to wash.
Dec 31, 2012 • Cats
1helpful
5answers
I'm thinking of buying a heated cat bed for my cat, are there different types?
There arelots of different types of heated cat beds. I\'ve seen lots of different shapes,colors, materials etc. You can even personalize your cat bed.
Jul 23, 2012 • Cats
3helpful
Install of AS 2425 whirlpool tub
hey bill no easy way what we do is measure height of edge that will sit on stud and tack stud in tub area and dry fit tub.when you do that you can see how much space is under tub for your mortor you should use light weight cement called structolite its white and not as heavy and yes a piece of tar or resin paper is a good idea
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
