When set to Cold/Cold cycle, it pipes hot only. I turned the the hot water off and observed that no cold water runs. Instead a load noses like trying to open some kind of flapper. It is not a click noise but more sounds like a flapping. Please advise which part should I order.
Thanks
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
