Hydronic switch open
9 E9 Hydronic switch open (if hydronic configured) - either the aquastat is defective, or the aquastat wiring is cut, or the aquastat is not present at all and the aquastat wires were not permanently connected together as per the set-up instructions.
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
I have seen this happen many times and if you cannot relocate the bulb of the thermostat to keep it form short cycling, I have mounted a wall thermostat and disconnected the thermostat in the PTAC and wired it in to the wall stat. You may have to install a wall stat in the center of the room away from the bar.
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
