Canon ZR90 Mini DV Digital Camcorder Logo
A
Anonymous Posted on Mar 14, 2014
Meaning of a red warrning icons - Canon ZR90 Mini DV Digital Camcorder
Why does my tracphone have a red exclamation on the home screen?
What does it mean when my samsung tracfone shows a ...
www.askmefast.com/What_does_it_mean_when_my_samsung_tracfone...
What does it mean to have a icon appear on my samsung flip phone with icon little phone with ..... A symbol of a phone and exclamation point on my tracfone screen .... "The main screen that looks like a telephone with a red explanation mark.
Phone symbol W/ RED exclamation point? - BlackBerry Forums at ...
forums.crackberry.com > BlackBerry 10 Phones & OS > BlackBerry Z10
May 18, 2013 - 8 posts - ‎5 authors Now that I wanna take a screen shot of it it goes away. But your answers ... Red exclamation point next to e-mail on curve. By jr369 in forum ...
Exclamation LG 840G Tracfone/Safelink help! - Howard Forums
www.howardforums.com > ... > Tracfone/Net10
Aug 17, 2013 - 15 posts - ‎7 authors From the main screen, press the "Applications" icon at the bottom right of the ... i havethe same phone, can the lg840g be used with safelink?
I have a red light indicator on top of the water icon
Pretty simple - that typically means replace the water filter.
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 • Drills
1helpful
99 subaru outback
AT Oil Temperature is probably "Automatic Transmission".You may need a transmission flush(do not confuse this with a fluid and filter change).Or,it could be a bad sensor or trans thermostat.
2helpful
An icon came up and i dont know what it means
That is your coolant light. When the coolant is cold (car is cold) it is blue for a moment then goes out.
When the coolant is too hot, it is red.
When it flashes, you are low on coolant. Check the coolant tank level (it is the big ball shaped reservoir) and make sure you are within the operating level (about half way up, there are marks indicating proper level)
NO POWER
sounds like a heat sensor or fan problem. How old is the lamp, lamp hours etc.
http://www.youtube.com/watch?v=HvZ2DlVJ790
http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com [email protected] +64-9-414 2348
My pink Alcatel S319 has a phone icon with a red X on the screen
Means u have missed call, just check your missed call to clear red X
Jun 14, 2009 • Cell Phones
Icons and what do they mean
Speed cameras usually are located either at intersections or along roadways. Many red light camera models used at traffic intersections also function as speed cameras. These speed cameras will mail you a speeding citation if the camera thinks that you are speeding. Your GPS navigator is warning you about nearby speed cameras. It displays red as you approach the speed camera location where you could get an automatic electronic ticket if you are speeding.
6helpful
2answers
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
1helpful
Red flashing icon
Mine had that too. It means the backup battery is low. It's located in a panel behind the LCD screen. You can find details on page 19 of the users manual. If you don't have your manual, you can download it for free from canon's website.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
