I am not getting digital chanels. I have scanned, it says it is searching for digital chanels but only comes up with analog chanels. What is up? I have an HGTV antena also, so why am I not getting digital chanels?
I checked out the manual for a similar model tv from polaroid...there's only one input for the coax cable from your antenna, so if the antenna's cable is connected to this input, this couldn't be the problem. What I do have trouble with on my own tv is that my indoor antenna location can make huge differences in recognizing all available digital signals. I could even have the antenna facing a different direction, and get different results. There are a few sites you can google for to find your distance from the broadcast towers, too. This might help to determine if you need a stronger antenna. It's a painfully long procedure to try different angles and positions for your antenna each time you run a channel scan, but this might be the only thing that would prevent you from picking up the digitals. I try the highest spot possible, and the one closest to the outdoors. Good luck, I hope you can pick them up soon! (Any antenna works...the industry tries to pass off "digital/hdtv specific antennas" to make a buck. I've used a cheapy rabbit-ears antenna and was able to bring in digital channels, as long as your tv or converter box is converting the signal.)
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
