* The solution, in a nutshell, is to disable your firewall. If you’re using McAfee Personal Firewall Plus, F-Secure Internet Security, Norton Internet Security or another Firewall vendor, see its respective support page for assistance in disabling it (temporarily). If you’re using the built-in Vista Firewall, keep reading.
* Open the Control Panel and select Security.
* Select Turn Windows Firewall on or off.
* Select Off (not recommended), click Apply and then OK.
* Back at the Windows Update screen, click the Try again button.
* The download(s) and installation should start…
* and this time successfully install. If a restart is required, make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors
you can download it from softpedia or dozens of places if you google it download it els where and install it that way i see alot of users have this issue i would also make sure your time date and time zone are correct if you still cant install it from the end user installer . *****http://www.softpedia.com/progDownload/Windows-Vista-Service-Pack-2-Download-112640.html here is the link i would try *****right click your my computer go to properties and find out if you have 64bit windows if so you need to download the x64 version if not x86 is for you food luck
Press Win+R, type 'services.msc' and press Enter. Respond to the UAC prompt. Check that Background Intelligent Transfer Service is started and its startup type is 'Automatic.' (It can also be Automatic (Delayed Start).) If it is not started, right-click on it and select Start. Scroll down to Windows Update to make sure that it is started and it startup type is 'Automatic' or 'Automatic (Delayed Start).' If it is not started, right-click on it and select Start. If you had to start either service, try to run Windows Update again by clicking on Start -> All Programs -> Windows Update.
1: Open up "Control Panel" and navigate your way to "Programs and Features".
2: Click "View installed updates" on the left hand side.
3: Find the update KB929777 and uninstall it.
4: Attempt to install the update again in Windows Update
5: Once successful, restart your PC.
and if it works thats good but if it ddnt let me know plz
