Check if compressor is starting and the click start of the compressor starting. After that refrigerator should have humming vibration. If yes then check the thermistor or replace THERMISTOR. Actually thermistor's job is to sense the cooling temperature. If THERMISTOR is faulty then ice formation will not happen. Once desired temperature reaches then thermistor activates relay attached with compressor for autocut.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
