If you are trying to do this by setting borders manually you are probably running into the Canon's minefield of "minimal printed borders" which throw off calculations. The manual setting is primarily for off-setting images rather than for perfectly centered images.
For a centered image, the borders are automatically set by the relationship of image sizing to paper size, with "center image" checked and other sizing options unchecked. This has worked perfectly in the three Canon printers I've owned, whereas trying to set even borders manually was always off a bit and a real pain.
If you want the same border width for all sides, the aspect ratio of the paper and image will have to be different, strangely enough, for all but square images. For 1" borders all around on 10x15 paper, e.g., your 2:3 AR image will have to be cropped and sized to 8X13" dimensions.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For
Canon Printer Support
