Sharp R-510HW Microwave Oven Logo
A
Anonymous Posted on Mar 12, 2014
Will not turn off - Sharp R-510HW Microwave Oven
Turn table on microwave keeps turning
Is it turning when the unit is not being used? If so there is no user serviceable parts inside please seek repair. If it only turns while in operation this may be normal as most do not allow you to turn off the turn table.
Good luck
https://www.6ya.com/mrmmike
I have a kitchen aid microwave and when turning on sounds like the bird chirping around the bottom of the unit.
Does it have the option to turn the turn table off if so turn it off and see if noise goes away if so turn table motor very common over time it will default back to on on next cycle
Why turntable will not turn
You either have a bad turntable motor, or else a bad (broken) shaft coupler.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
My rollers don't turn
may sound stupit but are the rollers clean and does the pice in the middle that turns them turn when its not in or is the wrong playe in there or your belt could be broken that turns it
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Turn table doesn't turn
Is the plate engaging the drive?
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Not turning
r u putting heavy stuff on it? if not, then its probably how it is and u should exchange it.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
