Computers & Internet Logo
A
Anonymous Posted on Mar 12, 2014
How to flash bios
I need to enter q flash, but nothing is working... Help, please!
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
2answers
Dell 1525 Stuck at DELL Screen
The bios is working fine its the little program that runs the system like run the setup, entering set up is not running because the file are not there you need to use and run setup from a cd
2answers
BIOS flashing problem. Latest BIOS from Biostar site is on flash drive, F12 during POST opens the flash screen, file is selected; but then the process hangs at blinking message "Reading file, please wait",...
If I am right, writing Bios files isn't possible with your Motherboard Bios Flash Memory. I've done updating bios on many motherboards, but most of them can't be written, when I contact the manufacturers, they only say that I must have done something wrong, following the instructions, but with the same instructions and procedures, it worked on some motherboards. Not all motherboards support flashing bios, since some bus and flash memory are faster and some are not. Sometimes your pendrive (flash drive) creates this problem, so I would suggest you to use another flash drive. I hope you did format the flash drive before you write the Bios updates files, if not, you should do it and you have to write the files on an empty drive.
(This isn't a solution, only an assistance, if this doesn't help, you can still ask for another expert's help)
Good luck.
Thanks for using FixYa.
Bios problems
If this is under warenty take it in if not your going to need to access inside of it and move the bios jumper and the flash the bios again, This time back to its orginal settings before you did this.
Remember if there was nothing wrong with the computer in the first place you nevr want to flash the bios i do not care if its a unpdated one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2answers
USB Ports won't work
Please enter CMOS setup and verify that the USB port is enabled.
BIOS flashed with wrong version
Remove the CMOS battery will reset the bios ( not sure how you could have installed incorrect bios it would tell you it the wrong bios )
2answers
Hp nc6320 laptop
No problem. You need to enter The bios, And get the computer to start from The CD/DVD rom drive.
Put windows in the Drive, and you should be able to reboot from there with options to Format et,c.
Any problems Just Ask.
Regards mike @ compurepair.
Can't change any settings in BIOS on Abit At7-MAX2 model KT400-8235
It is possible that the bios is damaged. You ran the flash utility correctly by what you posted. It would be worth it. Most companies chargh $5.00 us. Can't beat that.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
