Konica Minolta "Minolta Bizhub 363 Copier, Printer, Scanner" Logo
A
Anonymous Posted on Mar 12, 2014
How to scan full page not book copy
I am scanning multiple documents and sending them to my computer. The documents are bookcopy even though I am scanning single pages. I want them full size.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Nov 15, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1911965
Points
11959
1helpful
2answers
How do I scan multiple pages with readiris
Google is ALWAYS the first place to check. Just search for scan multiple pages hp readiris
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Hp 4345
Check ADF unit (automatic document feeder) working condition.
For diagnoses : Insert few paper(ex:10papers) in ADF unit & do copying, if UR succeed in copying, ADF is working well.. If not check the fault.
HP M4345 facilitated with digital sending option., for configuring digital sending U need to create shared folder with fully permissions in system. Better visit hp site or google to know about how to create folder.. You can do multiple scanning once configuration completed successfully..for more info visit:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c02720194-2%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1409945500358.876444892.492883150
1helpful
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
1helpful
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
5helpful
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
2helpful
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
How could i make a duplex copy, where do i have to go
Duplexor printing is the only feature which HP All-In-One printer offers, where you can print in both sides of the paper from your computer if you have multiple pages to print.
But SORRY you cannot make a duplex copy on the stand alone machine itself.
But still you can scan and print the same on the duplexor.
For Scanning Multiple pages in one Folder:
All you need to do is if the All-In-One Printer driver and software is completly installed in your computer, Then you should have a icon in your desktop as HP Solution Center / Go to
Start> All Programs> HP> HP Solution Center>
Then click on Scan document> The in the option where it says Where do you want to send the scanned documents> Click on the drop down and select PDF / Word then make syre you
have selected Show preivew Box> Then click On Scan>
After it shows the preivew> Click on I Accept> NOW IT WILL ASK IF YOU WANT TO SCAN ANOTHER DOCUMENT> Click yes on this and replace the document> and the click on
NEW SCAN> and follow the same steps to scan multiple pages, till you have finished scanning all and then> When it asks if you want to scan another document> Click on No.
And then print the same through the duplexor
Good Luck
2helpful
Scanning multiple pages into one folder that can be attached
All you need to do is if the All-In-One Printer driver and software is completly installed in your computer, Then you should have a icon in your desktop as HP Solution Center / Go to Start> All Programs> HP> HP Solution Center>
Then click on Scan document> The in the option where it says Where do you want to send the scanned documents> Click on the drop down and select PDF / Word then make syre you have selected Show preivew Box> Then click On Scan>
After it shows the preivew> Click on I Accept> NOW IT WILL ASK IF YOU WANT TO SCAN ANOTHER DOCUMENT> Click yes on this and replace the document> and the click on NEW SCAN> and follow the same steps to scan multiple pages, till you have finished scanning all and then> When it asks if you want to scan another document> Click on No.
Check and see if it works, If any help or problem let me know
Good Luck
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
1helpful
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
