Model number wsm2420taacc. checked continuity on the lid switch and pressure switch, also checked for clogs going between pressure switch and wash tub. capacitor will charge when unit is plugged in so I thought it was the timer. replaced the timer and still nothing. I know from calling ge's answer center that this is a unit from the early 2000's but she told me I would have to call a service tech. not very helpful
Http://www.appliancepartspros.com/parts-for-ge-wsm2420taacc.html
It looks serious problem. You should go to your nearest repairer to solve the problems if you don't want to stay without your washer.
SOURCE: Washer/Dryer
lincoln, there should be two clips on each side just below the top. Take a puddy knife and push in on the clips. The front panel should release and pull foward. Catriver..post back.
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
unfortunately I do not have a schematic for this unit. I picked it up second hand with no documentation
i was kinda hoping somebody on here would have access to one
thanks john. i found that site too but i was looking more for a wiring diagram
For $9.95 you can download the service manual at:http://www.allrepairmanuals.com/ge-washe...
