The receiver will turn on and make that "click" noise that it always did shortly after powering up. But it won't have any sound output. I tried reconnecting the speakers, and totally different speakers as well but nothing. I also wasn't blasting it at a loud volume when the receiver stopped. I was plugging an aux cord into my laptop when with the volume around 30 when it made a huge thumb sound and never had sound output again.
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
SOURCE: Sherwood RX-4109 receiver has no
Maybe a shorted right speaker took out the other channel. Does it turn on now? Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
You can test the speaker for open or short by touching a small battery to the speaker wires. It should make static or click sounds. If not, it's dead. If it sparks and akes no sound it's shorted and dangerous to any amp.
SOURCE: I would like to connect
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
SOURCE: Sherwood RX-4105 Receiver will not stay on
you denon guys go into your manuel and look-up protection mode and how to reset your recievers oh did you use the adussey microphone to set it up it will make a world of difference in sound oh i own a home theatyer store in michigan called theaterxtreme 1-248-456-1800 my name is terry
SOURCE: Why do my right speaker inputs cause fuzzy sound?
HI KYLE...
I think I have experienced this problem before with my Sony stereo set. It could be a sign that your receiver's amplifier is giving out. Best that you can do is bring it over to an audio repair shop for a checkup. If my suspicion is right, you're gonna have to replace it with a new one. Don't worry, amplifier chips are not that expensive.
And lastly, when any part or component is replaced, be sure to ask the technician to give it to you. You can keep it for your reference.
BOB (June 23rd '12 3:20am)
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
