Technics SL-MC6 CD Player Logo
A
Anonymous Posted on Mar 11, 2014
Need drive belts - Technics SL-MC6 CD Player
Steve K
Level 3:
Genius:
  • Technics Master 1,054 Answers
  • Posted on Sep 28, 2015
Steve K
Technics Master
Level 3:
Genius:
Answers
1054
Questions
0
Helped
574188
Points
2865
Easiest way is to take the old belts to your local ace hardware and find an o-ring that is the right size
Replace drive belt Bosch pbs7a
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
1helpful
2answers
85 chevy celebrity. replaced alternator. that one squealed 2. got another. still hear a squeel. does not squeel when belt is off.
ALTERNATOR BELT NEED ADJUSTING AND REPLACING IT GLAZED. WHEN DRIVE BELT GET GLAZED SHINY CAUSE IT TO SLIP AND SQUEAL.REPLACE ALTERNATOR DRIVE BELT. AND ADJUST IT DRIVE BELT TENSION BY TIGHTEN THE UNTIL YOU CAN PRESS DOWN ON THE BELT IN THE LONGEST RUN. YOU NEED TO PRESS DOWN BELT AND GET A 1/4 TO 1/2 INCH DEFLECTION IN BELT.THE BELT CANT BE TOO TIGHT WHERE WHEN YOU PRESS DOWN AT IT WONT GIVE IN NONE TOO TIGHT, WILL CAUSE PREMATURE ALTERNATOR BEARING FAILURE IF DRIVE BELT TOO TIGHT.
I need a belt diagram for a Mercury Grand Marquis 4.6L V8 engine 2006
SECTION 303-05: Accessory Drive 2006 Crown Victoria/Grand Marquis Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 03/18/2008 Accessory Drive adobe.gif Printable View (104 KB) The accessory drive system:
  • has a single serpentine accessory drive belt with 6 ribs.
  • has an idler pulley.
  • has an automatic drive belt tensioner.
  • is not adjustable.
The accessory drive system provides power to operate components which power other systems. These could include components such as the generator, power steering pump and A/C compressor. Each of these components is equipped with a pulley which is driven by the accessory drive belt. The accessory drive belt is driven by the engine crankshaft pulley. One or more idler pulleys may be provided to facilitate belt routing and alignment. The automatic belt tensioner maintains correct belt tension and compensates for component wear and changes in system load. System load changes can be caused by the A/C compressor clutch engaging or disengaging, or demand changes on other systems powered by the accessory drive belt. To maintain correct operation of this system, it is critical that the correct length drive belt be installed. The pulleys must also be correctly aligned and kept clean.
Accessory Drive Belt Routing
Item Part Number Description 1 8678 Accessory drive belt idler pulley 2 10344 Generator pulley 3 8620 Accessory drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Coolant pump pulley 7 2E884 A/C clutch pulley 8 6B209 Accessory drive belt tensioner pulley Belt Tensioner
Automatic tensioners are calibrated to provide the correct amount of tension to the belt for a given accessory drive system. Unless a spring or damping band within the tensioner assembly breaks, or some other mechanical part of the tensioner fails, there is no need to check the tensioner for correct tension.
2010&c18=modelyear&c20=n924137&c35=wsm%2caccessory%20drive%2cs6a%2c303-05%2cdescription%20and%20operation&s=1249x702&c=32&j=1.3&v=y&k=y&bw=910&bh=359&ct=lan&hp=n&[aqe]
1helpful
Belt is slipping and I need to know what maintenance I should be doing on this model as I have no manual for it.
Hello, There is no maintenace required. Some people like to oil the walk belt, The manual say to do this annually. To do this you loosen the walk belt and applty some synthetic oil to the walk board under the walk belt, then tighten the belt and the belt will distribute the oil where it needs to go. As far as the walk belt, just make sure that is stays in the center of the walk board. Now your front roller and drive belt. The roller does not get serviced, it has perminently sealed bearings. The drive belt usually lasts for many years, if you remove the motor hood and see alot of black dust, it will be the belt. At that point you need to see why it is comming apart/rubbing. After you determine that, you would want to replace it.
The slipping you are describing could be the drive belt slipping on the front roller or the drive pully on the front roller. To find out you need to remove the motor hood nad get on it and look. What you will be watching is the drive belt as it goes from the drive motor to the drive pully. When you try to stop the walk belt you will either stop the drive belt or stop the walk belt. If you stop both, the drive belt is at fault, if the motor keeps turning. If you stop the motor, the motor or the controller is bad. If you stop the walkbelt and not the drivebelt you have a bad drive pully on the front roller, and need to replace the front roller. When you do this you need to remove the drive belt, this is a ggod time to replace it.
Hope this helps, rate my solution if it helped you. Thanks, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
I need a diagram for a installing a serpintine belt in a 2005 toyota tacoma
Depends on engine. Copied below diagrams from AutoZone.com:
Drive Belt Routings
0996b43f80209580.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.4L engine
0996b43f80209581.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.7L (3RZ-FE/M) engine
0996b43f8020209e.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.7L (2TR-FE) engine
0996b43f80209582.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-3.4L engine
3answers
My 1998 Windstar with the 3.0L engine needs an alternator. Easy enough fix except I don't know how to work with the serpentine belt (all my other vehicles are old skool). Where is the tensioner and how do...
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP.
    Using a 15 mm socket or wrench attached on drive belt tensioner pulley bolt. Rotate drive belt tensioner (6B209) clockwise to remove drive belt from pulleys.
    Pulley Routing, Accessory Drive Belt—3.0L Engine
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator 3 6B217 Drive Belt Tensioner Pulley 4 6B209 Drive Belt Tensioner 5 3A733 Power Steering Pump Pulley 6 19703 A/C Compressor 7 6312 Crankshaft Pulley 8 8509 Water Pump Pulley
Installation
  1. Install drive belt over all accessory pulleys (except drive belt tensioner ).
  1. Rotate drive belt tensioner as described under Removal to install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys.
1helpful
Need a diagram on how to refit fan belt
Like a lot of people...you didn't post your engine size....so out of these 11 photos, please choose the correct one for your application:
Accessory drive belt routing—1.8L (AEB/ATW/AWM) engines
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines with A/C
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines with A/C
Accessory drive belt routing—2.0L (ABA) engine without A/C
Accessory drive belt routing—2.0L (ABA) engine with A/C
Accessory drive belt routing—2.5L (BGP) engine with A/C
Accessory drive belt routing—2.8L (AFP/BDF) engines
Accessory drive belt routing—2.8L (ATQ) engines
Accessory drive belt routing—4.0L (BDP) engine
Need to change idler pulley on a 95 explorer
it's metric. Do you have 2.3L 4 cylinder, 3.0L 6 cyl or 4.0L 6 cyl?
Drive Belt Tensioner, Automatic Removal and Installation
  1. Remove drive belt (8620) as described in this section.
  1. Remove drive belt tensioner retainer bolt and drive belt tensioner (6B209) .
  1. To install, reverse removal procedure. Tighten drive belt tensioner retainer bolt to 83 Nm (62 lb-ft).
4answers
Drive Belt needed
I have a Regal Kitchen Pro Bread machine K6773 that I'm junking. I'll sell you the belt for $5 + $5 shipping. Contact me at [email protected]
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
