We put sd card 32g in and took old out. Now I csnnot get anything to save to sd card and cannot move apps to the sd card either.
One question. Were you able to move apps to the sd card before?
When you go to settings, storage, does it show the external sd card? I want to explain something first. The sd card is an expandable storage card, but it won't store your apps. If you want to check it out just insert the old memory card in a computer and look for any apps. Smartphones usually comes equip with 2 types of storage:
1. Internal phone memory: which could range from 500mb. to 2gb. of storage. This will be by default the location where the apps would be saved.
2. Internal SD Card: this is an expand storage that is already in the smartphone. Notice that when you see an ad for the phone it usually advertise whether it is 4, 8 or 16gb. That is the internal SD storage.
The third option is the external micro sd card, which is the one you are having problem with.
In storage under settings, see if you have an option to mount the sd card, maybe it's not mounted. You can also clon or copy everything from the old sd card to the new sd card using a computer, and then try it again.
