Turn on from standby. Full picture and sound come on. TV unresponsive to remote or side buttons. Picture and sound go off but no diagnostic lights come on. Lamp is still lit but no picture appears on screen. Then picture comes on again but this time sound cuts out after a second or two. Picture stays on for approx 30 sec and cuts out again. Approx 50 sec later picture comes back. Neither remote nor set buttons work. This repeats a few more times and finally picture goes out and standby diagnostic light comes on steady.
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Testimonial: "Thanks Col Dana Gillespie. Not solved so far. see comment."
Standby led light does not blink at all. After cycles of off and on with no led lights, the standby light comes on and stays steady with TV off. Possibilities I've heard of from the Internet: defective safety switch on lamp cover, defective temperature sensor, one or more fans not working leading to overheating, bad capacitors on dmd board or power supply board ( are they the same in the HLR5078w?) , failure of prohibitively expensive dmd board. Samsung says my model was not part of the capacitor recall suit.
OK I stand corrected, I should have done more research. I was thinking of a flat screen TV, On that type of TV the DLP you have many and I mean many things that can go wrong, I have several here (different brands) junked because when I would get one thing fixed something else would go wrong. Of all the electronic equipment I have worked on in my 33 years as an Electronics Technician those TV are the most complicated pieces of equipment I have ever worked on, They have four or five fans, a Backlight and a door switch,as you mentioned can close OK but still be bad. A ballast for the backlight that often gives trouble by over heating, and the list goes on. I am sorry, if I had it in the shop I might be able to fix it but usually the parts alone are so expensive and hard to find that you can buy a new one for about what the parts are listed for. When I sa listed that's usually what they are is listed. They do not have any in stock. Unless this TV has some kind of a sentimental value to you I would advise you to try and get a newer flat screen. I was in Goodwill the other day and they had some good looking 52" inch TV's playing and they were dirt cheap. Pawn shops often have good TV's at a good price. If you get a flat screen and ever need a board for it contact me. I have a pile of boards left over and if I have what you need I will ship it to you at no cost. Sorry I couldn't be of more help but if I can do anything else to help you just email me anytime.
Thanks again for answering. You are probably wise in your suggestion to cut my losses. It is just very frustrating that the TV is obviously 99 and 44/100% fine and has to be junked because of failure of a part that realistically has a very low cost of materials. Even if I get a tech out here for $100 service fee, will he know whether it's a sensor or switch that costs pennies or a dmd board which costs ~$600 - a core fee refund (maybe)? I'll let you know if I pursue this further.
SOURCE: t.v. will not turn on. flahes "lamp" then no picture!
I have a picture but the tv will periodically turn itself off during the day and then flash the 3 blinking lights...anyone know what the problem could be. We can fix it ourselves if we knew for sure what it is.
SOURCE: Samsung HL5067W power cycling
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
SOURCE: sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
