That's a dead battery reset code for your factory radio if your battery dies you have to reset your radio and all presets it's just telling you for some reason
code p 2227 refers to Barometric pressure sensor(BARO)---range /performance problem===causes ---wiring---BARO sensor---ECM
to remove the fault , replace the sensor then use a scan tool to reset the ECM
Usually what that means is that the genset Configuration is not set correctly you will need to bring it to a factory authorized service center for them to correct this.
The exact same set of codes have just come up on my car, the same car and year. Did you solve it? I am thinking cleaning the throttle body first, any help appreciated....
