Question about American Standard Colony 2388.012.222 Linen Two-Piece Round Front Toilet
My toilet keeps leaking from tank to bowl--replaced all internal parts
Not sure which American Standard -- it has been in my house for 20 years I think. This toilet has had problems with leaking from tank to bowl for years. Food color indicates this and so does my $100 water bill (doubled). Internal parts/assemblhave been replaced numerous times and so has the flapper (the last plumber said the other one wasn't the right size - and yet...it lasted for a few billing cycles and wham..back at it and color down in the tank. Should we replace the whole toilet now and start over - perhaps parts are not compatible with old toilet any longer or there is a seating/sewer/suction issue or whatnot?
  • Tammy Bauer
    Tammy Bauer Mar 12, 2014
    Thanks, John, I will check this out. I really appreciate your help and this website. God bless,
  • 794 Answers
Is the water closet (the tank where the water sits in) level? Front to back and side to side? Is the water level to high where the excess water is traveling down the tank overflow assembly? When you replace the parts, are there any mineral deposits (lime or calcium) or any other type of slime build-up on the water control diaphragm (flapper)? or on the flush valve seat that the flapper closes on? Do you have the chain that connects the trip lever to the flapper adjusted properly? Check the flapper alignment to the seat of the flush valve. Other things to look for,
  • The small rubber fill tube leading from the valve to the overflow tube and sometimes the valve itself can act as a siphon. In that case, adjust the valve height or tube height up, or adjust the water level down.
  • The water pressure at the small rubber fill tube leading to the overflow tube may be too high, preventing the flapper valve from seating. Turn the shutoff valve at the wall partially closed.
  • Or simply wait and watch; remove the tank lid, flush the toilet, and see what's going on...or better yet, what's not happening.
  • Have your water tested to see if there are any other contaminates that may be fouling up and deteriorating the internal parts of the toilet, like too much chlorine, magnesium, or iron.
Either way, you should not be going through...or have to change the guts of your toilet as frequently as you describe; it's either a mechanical or design defect, tweaking adjustment, or an environmental one that is causing the parts in your toilet to deteriorate prematurely.
Best regards
Posted on Mar 11, 2014
Testimonial: "Thanks so much, John, I will check all of the input I received to see if I can make adjustments before replacing the entire toilet. I really appreciate this website--God bless you all! Tammy"
  • 846 Answers
If the flapper and all has been replaced. then it must be worn out where the flapper sits. or its not smooth.check to make sure it is smooth where the flapper closes, and make sure it closes fully when flushed. you might be better off with a new toilet, but thats up to you!
Testimonial: "Hi Carl, I have had the flapper replaced a lot of times (the last plumber said the previous one was the wrong size). I will check this one though, and will adjust the chain and the water level tube/float. God bless you for your help! Tammy"
6ya staff
SOURCE:
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
Steve Darnell
  • 117 Answers
SOURCE: water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Posted on Aug 03, 2009
shepnaz400ex
Tony Sheppard
  • 46 Answers
SOURCE: How much draw down (tightening) do use to attach
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Posted on Sep 04, 2009
Larry Maranto
  • 198 Answers
SOURCE: problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
Posted on May 09, 2010
William Shores
SOURCE: hole in back of toilet (stool) leaks water.
Mine don't leak but the toilet suffered from the lazy flush until I found the hole and covered it with masking tape.
Posted on Aug 18, 2010
Hello, I have an old American Standard toilet (1985) and one of the bolts that holds the fill tank to the actual toilet bowl is leaking......
Yes, those parts are a 'Standard' (excuse pun) part. Replace them both and the seal between the tank and bowl. Buy a small tube of silicone too. There are bound to be videos of how to replace. It is fairly straight forward. Don't overtighten the bolts, finger tight and a quarter turn.
Sep 29, 2016 | American Standard Home
New toilet 540 fluidmaster water in tank keeps topping off every half hour
The problem may be the flapper that seals between the tank and bowl is leaking or the overflow pipe may have a crack in it. I wouled replace the flapper first and check the overflow pipe for cracks.
Hope this helps.
Bob
Oct 08, 2014 | American Standard Home
The water runs out of my water tank Need a red rubber ring for an american standard 4260 toilet
Is it leaking on the floor, or just into the bowl.
You can find replacement parts at any hardware or plumbing store.
Aug 26, 2011 | American Standard Home
About every 20 minutes or so, more water is released into the bowl from the tank. Toilet is less than 1 yr old ,model 4021
The flapper that stops water from entering the bowl after flushing needs adjustment. The chain is probably to short.
Aug 20, 2011 | American Standard 4021 White Cadet 3...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
Slow leak from tank into bowl. We can hear tank refilling once or twice a night.
I'm contractor for the last 17 years and this is the first time I have problems with the toilet tank installation , I bought four toilets, three of them had a leaking tank I thought that the place that had bolt did not have enough pressure and I put more pressure every five minutes but the toilets kept on leaking, I took the bolts out and I put plumbing putty in the top and the bottom and installed it again but it kept on leaking then i removed the putty and i put liquid teflon on the bolts and finally the leaking stoped. Edit your post: insert-link-blue._v192249896_.gif To insert a product link use the format: [[ASIN:ASIN product-title]] (What's this?) I'm contractor for the last 17 years and this is the first time I have problems with the toilet tank installation , I bought four toilets, three of them had a leaking tank I thought that the place that had bolt did not have enough pressure and I put more pressure every five minutes but the toilets kept on leaking, I took the bolts out and I put plumbing putty in the top and the bottom and installed it again but it kept on leaking then i removed the putty and i put liquid teflon on the bolts and finally the leaking stoped. cancel-glossy._v192250345_.gif deletepost-glossy._v192250344_.gif Guidelines
Feb 04, 2011 | American Standard Cadet 3 Right Height...
Water leaks from tank to bowl till water level in the tank is jus
Aug 03, 2009 | American Standard 2002.014 - Champion4...
Champion4 leaks water through flush valve
You have replaced the flush valve completely? If so and the unit is still leaking, you may have a small crack in the tank or your just not getting the tank to bowl fittings tight enough. Also, they make two different thicknesses in the tank to bowl gasket. Make sure you are using the thicker of the two. You posted this under the American Std. thread, so if this is correct, give them a call. There could be a recall on this particular toilet due to a flaw.
Apr 04, 2009 | American Standard AMERICAN STD 12 RGH...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
American Standard Colony 2388.012.222 Linen Two-Piece Round Front Toilet Logo
151 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
