Washing Machines Logo
Terry Morehouse Posted on Mar 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kenmore super capacity 3.5 quiet tumble easy access frontload washer. I have tried it on every program and at the end of each cycle the light comes on showing final spin but all it does is drains and then just tumbles like it does when it's washing, it doesn't spin at high speed and the clothes stay soaked. PLEASE HELP... is there something I can do to fix this or is it even worth fixing?
rjkibbee
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2018
rjkibbee
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
874
Points
I have this same issue and cleaned the pump out, checked the door latch, checked the control board and still no spun at the end of the cycles. Does anyone know if these super capacity 3.5's have a clutch Tanna system that would cause this?
Thanks
Rick Arnold
Level 2:
  • Expert 63 Answers
  • Posted on Mar 11, 2014
 Rick Arnold
Expert
Level 2:
Answers
63
Questions
0
Helped
33312
Points
120
Try cleaning your pump filter and pump, if the pump is not working correctly the machine will sense this and flash warning lights.
Good luck
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
We have a Kenmore 3.5 Super Capacity Quiet Tumble Action Wash Easy Access. The spin cycle works however the water won't drain and our laundry is soaked. Help...
It could be either the pump or a clog in the discharge hose. Take a shop vac and attach it to the discharge hose to remove the water from the machine. Remove the pump housing and run a wire down the discharge hose to check for a clog. If there is no obstructions, reattach the pump housing and remove the pump motor. Run a spin cycle and see if the pump motor turns.
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
2helpful
I have a Kennmore super capacity 3.5 quiet tumble,action wash,easy access washer. The problem is, it won't do the spin cycle and clothes are coming out wet. I looked at the tech sheet and it says to check...
You might want to check the plumbing in the bottom of the machine for clogs. On most modern washers, the spin cycle will not start if the water is not completely drained or doesn't drain fast enough. I had a similar problem and found a there was a rubber fitting with a plastic cup inside that serves as a trap to prevent debris from entering the pump. It had a piece of scotchbrite, forty cents worth of change and a hairpin stuck in it.
2helpful
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Alexander
vince
