Sylvania SDVD7015 7 in Portable DVD Player Logo
A
Anonymous Posted on Mar 11, 2014
Sdvd7015 dvd player
Hook up to tv
No disc
Get a Q-Tip and rubbing alcohol, gently clean the laser lens and allow several minutes to dry. If there is no change the whole laser pickup assembly will need to be replaced, not cost effective to repair, cheaper to replace the player.
Sylvania sdvd7015 just loads and then says no disc
Check and replace the optical pickup unit. For more details type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
2answers
I have a Sylvania sdvd7015 that had the 120v wall adapter cord crack and short out while a DVD was playing. The screen stopped playing and gradually faded to white and then went black. The car charger...
I have serviced a lot of portable dvd players, when the adaper shorts in the manner you describe it usually takes out the pcb board making it not cost effective to repair, far cheaper to replace the whole unit.
1helpful
Need to replace the Av cable that came with the unit
Tries websites like Amazon.com,Ebay.com to buy a replacement of the AV cable.
Dvd player will only play cds, not dvds
hi,
ur dvd players laser pickup unit or the spindle motor may be get damaged. first of check the spindile motor . just try to rotate with ur finger it should freely run for a moment. if feel tight ,first replace the same. after that, if the problem remains u have to replace the laser pickup unit.
ok
1helpful
Can I use a universal adapter as a replacement to charge SDVD7015
I am pretty sure it also came with a 12V cord for car use.That's means you can use a universal one with 120v input (USA) and 9.4V 400 ma. or a little bit higher (like 1 amp or so ) for your output.Look where the plug gets into your unit and make sure the polarity is the same.
I put a dvd in and after a minute of cycling it say ''no disc''. Its a Curtis sdvd7015 portable dvd player and the dvd is clean.
I've had similar problems with a number of my DVD players in the past. What always worked for me was to fiddle with the DVD door, i.e., press in slightly, press up or down, hold in place until DVD starts playing
Nov 18, 2009 • Cell Phones
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
