Question about Orion STV2763 27" TV
Need 3-digit code
Remote for satellite receiver won't allow tv to change volume or on off
I just recieved the Sylvania LC195SLX from my grandfather, it has no remote, but we are using dish network remote anyway, the channel is stuck on 5, and i can't change any channel or get a signal from...
Hello! I hope that you have gotten this resolved, but if not, here are some steps to do so. You can program the remote to the TV first and then use that for this, or you can use the buttons on the TV itself.
Remote to TV Steps:
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
527
733
632
Satellite picture back:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4.
If you are using a coax cable, the TV needs to be on 3 or 4.
Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | Sylvania LC195SLX LCD TV
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
May 31, 2011 | Sony RMYD028 Remote Control
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
I need the code for sharp tv please
Configuring codes:
  1. Turn on the component that you want to set up. In the code listing find the 4-digit code numbers for your component brand.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
    The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over.
Code Readback:
  1. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  2. Release the component key.
  3. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  4. Press the "enter" key.
  5. Count the number of times the green light blinks. There will be four numbers, separated by a two second pause. The red light will tum off after the remote is finished reading numbers back. Make sure you write the code number below for future use!
Multi-Component Power On/Off:
    The Jensen remote has the ability to turn On/Off multiple components at once. When you perform the following steps, you can turn On/Off the TV, VCR, Satellite, Cable Box and Audio Receiver.
  1. Press the "action" key.
  2. Press the "power" key. Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
    When you press the volume keys on the remote they will control the volume on your TV. If you have a home theater system and want the volume keys to control your receiver only, you may set your volume priority to the receiver.
  1. Hold the "RCVR" key down until the green indicator light comes on. The green light should come on after about 3 seconds.
  2. Press "RCVR" key.
  3. Press "Vol+" key. To disable the volume priority you have to set and return to the default.
    To change back to TV priority:
  3. Press "Vol-" key. The volume priority will now default to the TV volume.
hope this helps
Robb
Apr 22, 2010 | Jensen SC-570 Remote Control
I need a satellite Bell express Vue code (3100) I can't use the remote control Dish!!!!
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 23, 2010 | DISH Network IR Remote Control
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
I need 3 digit code for my Prima tv to program bell express vu
Dec 16, 2009 | Prima C2012 TV
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Orion STV2763 27" TV Logo
44 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
