Nikon N2020 35mm SLR Camera Logo
A
Anonymous Posted on Mar 10, 2014
How to load batteries in n2020 - Nikon N2020 35mm SLR Camera
How do I access the light meter battery compartment
Battery holder is under bottom cover. Remover large silver screw. Clean battery holder in case of leakage
1helpful
Power battery
It doesn't make that much difference, as long as you stick with the major brands. I've used both Duracell and Energizer, both rechargeables and alkalines, in my N2020. That wasn't an endorsement, just a statement regarding which batteries I had on hand.
2helpful
How to replace batteries in Nikon N2020...?
You can change the batteries without disturbing the film. The batteries go into the bottom. Use a coin to turn the screw on the bottom of the camera, then lift off the cover. The camera takes four AAA batteries.
If you need a manual, you may download a copy here. There are illustrated instructions on page 10.
I purchased some replacement AAA batteries for the camera. Nothing happens when I depress the shutter button. The camera is a Nikon N2020 AF. It has not been used for quite awhile. The batteries used...
Happy ending to this saga of the Nikon N2020 AF. I went to Walmart and purchased some real photo grade batteries. At first the result was the same, no apparent change, dead camera. I left the batteries in the camera overnight. The next day I tried depressing the shutter button with the camera turned on to S for single shot, and to my amazement the camera came alive! I don't know why or how but now it works and I don't have to bring it in for servicing. Today we will be off to the local zoo to take some shots. Can't wait. Thanks for all the comments and suggestions.
I installed new batteries in my camera. I turn the on knob and camera does not operate. Something wrong with power system Contacts are clean, new batteries Nikon N2020
"Turn the on knob"? You turn on the N2020 by lightly pressing the shutter release button. Do the meter indicator LEDs inside the viewfinder light up when you lightly press the shutter release button?
Where is the rewind button for the N2020? How exactly do I rewind my film?
it is on the top, a lock button you press down and a slide button that engages the rewind, if the batteries are dead it will not rewind.
My Nikon N2020 will not open to insert film
life up on manual film rewinder to release the the back to load film
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
