Question about Apple iBook G3 Mac Notebook
Reboot drive will not appear - Apple iBook G3 Mac Notebook
  • John Maliga Feb 19, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
How to install original settings to aspire netbook
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
hope this helps
Aug 17, 2012 | Computers & Internet
Want to install original settings
hope this helps
Aug 17, 2012 | Acer Aspire One D257 Netbook
How to install window xp
Hi, you will need to set up your hard drive first. During initial boot fase press the F8 key which will take you to the BIOS. Select boot device and change primary boot device to CD Rom. Insert XP Cd into drive, select save changes and reboot. Select boot from CD when this appears by pressing any key. Allow files to install, when this completes you will need to delete any previous operating system, partition hard drive and then format hard drive. Once this sompletes reboot, ignoring boot from CD this time and XP will start to install.
Aug 25, 2010 | Intel Motherboard
I have installed dual os(XP and Ubuntu Linux 10) on same drive It is working but my pc became very slow. Now I want to uninstall any or both os but it is showing error. So suggest me How can I?
Hi, try the following sequence.Insert your XP disk and reboot, during bootup press your ESC button or Del on some PCs, you will be in BIOS, from here you can change you primary boot drive, select CD rom, save changes and reboot. Press return when request to boot from CD appears, wait for the sequence to finish installing, select the section of the drive you wish to change, select delete, confirm and then reformat your hard drive. PC will reboot afterwards and start installing XP. Be aware this will remove everything from your hard drive, so back up first. Hope this helps
Jul 10, 2010 | Microsoft Windows XP Home Edition for PC
Have Dane-Elec 4 MB USB; works in one CPU great, in the other, I had to reboot, and then when I look at "My Computer" it appears and disappears every few seconds and I can't access it. Running XP both...
In Control Panel, click on "System." When the System dialog appears, Click on "Device Manager."
In Device Manager, click on "Disk Drives." That should drop-down and reveal your USB drive as a USB device.
Right click on your USB device and click uninstall, then reboot.
This procedure will uninstall the drivers for your device. After rebooting insert the USB drive into a port and a "Found new hardware" window should popup. allow internet access and reinstall the driver--this should be pretty much automatic; just make sure you allow the program to search the internet for the latest driver.
Good Luck!
Feb 21, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Laptop crash after inserting blank disk
do not worry at all. take out the cd and reboot in safe mode by pressing F8 at bootup. Then you can restore your laptop to an earlier date from Start->All progs->Accessories->System->restore. reboot normal this time.
Oct 04, 2009 | HP Computers & Internet
How do I remove or stop CHKDSK from running on my Inspiron 9300?
type cmd into the run box when you type that type chkdsk/f hit enter then type y hit inter again reboot let it run its test that should fix your issue
Mar 12, 2009 | Computers & Internet
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
Apple iBook G3 Mac Notebook Logo
67 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
